So the title says what I have. I would believe with the big OC I have on my 780 it would prob beat the 980 but I really want to use the 980's image scaling.
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/219791-980-v-780-lightning/
"980's image scaling."
hmm ?
DSR
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012811
980 beats 780TI how do you expect your 780 to win w/o  a world record winning OC?
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012815
780's are pretty fast at 1280mhz ya know :P. that would keep up with a stock 780ti
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012839
DSR is just downsampling
u can do it ur self
just look here
http://blog.metaclassofnil.com/?page_id=582
or
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012842
u can do it ur self
it's not
that thing in LTT's video works like this: your GPU outputs a higher resolution and your monitor downsamples it. this way, you're limited by your monitor capabilites, for example my 1080p monitor can't handle anything over 1440p
DSR makes the GPU render the scene at a higher resolution, then downsample it and send it to the monitor at native res, so the monitor isn't involved in the trick, you don't have to worry about it
so, long story short, DSR gives you a guaranteed good result
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012888
u can do it ur self
just look here
or
Yes but its a pain in the butt
| F@H STATS |
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012891
Yeah and with a WB (Don't have anymore) I got it to 1340Mhz
| F@H STATS |
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012899
it's not
Odd
my monitor cant downsample
(edit)
an option to use the GPU instead is presented (the option is given to me by default)
im on a GTX 570
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012908
that is a nice card. i would keep it i was you. it even has good memory, which is rare for a 780 lightning.
Rig Specs:
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012944
oh really? i missed that, is it somewhere in the nvidia control panel?
i edited my post
yeah its in the same place
in the video
4:37
"perform scaling on (BOX) display or GPU
for me its just GPU
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3012947
i edited my post
in the video
4:37
for me its just GPU
alright i found it and i played around with it a bit, but i'm not sure if that function actually does something
i'm still stuck at 1440p with my gtx770, and the bahaviour is the same with both options
i was actually disappointed that DSR won't come on kepler cards :(
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3013057
Would you go from a 780 to a 780 Ti? Because it's basically the same thing as going from a 780 to a 980. Only difference is the new "features" as far as performance goes not much of an improvement. The only reason why it might look there is improvements based on the benchmarks available is because they are running the 700 series at stock clocks (boosting to like 900MHz) and comparing them to 900 series cards that are boosting into the 1300MHz range.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3013361
There's some pretty dam good gains to be had going from a 780 to 980 even to a 970 would be good. But anyway a 23fps gain is quite large in BF4 http://www.techpowerup.com/reviews/EVGA/GTX_970_SC_ACX_Cooler/9.html
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3013484
^ This.
Useless post is useless.
Spam is spam.
My point is: try to either A: be original and B: if there's a post you agree with there's this thing called the like button which is far less spammy and accompolishes the same otherwise
but you could always OC the 780ti to recreate the gap... You're not guaranteed an OC... and there's still the gap from 780ti to 980... and you can OC 980 aswell.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3013617
Stock versus stock. Who cares about stock versus stock.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3013640
Oh come on @ stock the GTX 970 let alone the 980 has such a stagering lead that even OCed the 780 would have a hard time closing the gap. Not to meantion that the 9xx series OC better than the 780 and there really is no competition here. 970 cheaper to boot.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3013773
nvidia confirmed  that it will come on kepler soon  :)
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3015892
Uh there was a review of a 780 GHz Edition vs a 970 boosting into the high 1200s and the 780 was on par with the 970 in every game.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3017477
Ther was you swear it. You swear you seen it . You have no links to your claims though so links or it's BS. Every review I have read puts the 970 well in front of the R9 290 overall.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3019247
haha dreamer...not even close!
your overclocked 780 won't even touch a stock GTX 970 and those overclocks like beasts...let alone a 980.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3019262
I dont have a link because Im at work. It exists. Post it when I get home. I already disproved you about the 780 Ti and the 980 and you ignored those benchmarks. When I post these you will ignore those too.
https://linustechtips.com/topic/219791-980-v-780-lightning/#findComment-3019483
