Hello, I have a intel i7 4790k and stock fan. I edit normally and i monitor my temps using aida64, but it gets too hot.. sometime like 65 degrees celcius. Why is that??
65c is not hot.... When you get 75c+ that is hot. But an aftermarket cooler will do better.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/215412-too-hot/#findComment-2949952
65 degrees is not hot at all. 75-80 plus is hot.
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/215412-too-hot/#findComment-2949957
more work load increases the operations which causes more heat in a basic sense. also 65 degrees is nothing on an intel chip the Thermal limit on haswell is around 105 degrees staying below 90 degrees you are perfectly fine
https://linustechtips.com/topic/215412-too-hot/#findComment-2949972
65 degrees celsius is actually quite good considering it's a stock cooler. Be happy with it, your cpu is perfectly fine. Start worrying when you're nearing 80 degrees celsius if not oc'd.
CPU: i7-4770K  Cooler: NZXT X60  GPU: Asus GTX 770 2GB  MB: Asus Maximus VI Hero  RAM: Corsair Vengeance 16GB 1600MHz  PSU: Be Quiet! 630 Watt  Case: NZXT H440
       Storage: 120GB Samsung 840 Evo + 1TB Seagate HDD  KeyboardCorsair K70 RGB  MouseG502 Proteus Spectrum  HeadphoneSennheiser HD598  Mic: Blue Snowball Ice
https://linustechtips.com/topic/215412-too-hot/#findComment-2949975
But i rendered it once and it got to 80??? Should i upgrade my cooler
80 is hot, had you said that in the first case it would've been better.... Get a hyper 212 evo. It wont shut down the pc but it will throttle at 100c
https://linustechtips.com/topic/215412-too-hot/#findComment-2949981
What is the hottest point till where the comp can shut down
TJMax for 4790k is 102C if I remember correctly.
https://linustechtips.com/topic/215412-too-hot/#findComment-2950004
Got it.. i will get 212 evo!! and is the 212 evo east to install? or hard
Easy as, and you can youtube it to help you if you want.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/215412-too-hot/#findComment-2950050
i'd recommend watching some videos on installing it or picture guides etc. installing my zalman optima(very similar to the CM one, was nearly half price in a sale) was a pain in the butt. mostly because instruction booklet was ass backwards, had to kinda a-team it, cause most pictures were backwards or plain wrong for my am3+ socket mounting... backplate was pictures wrong way around etc.
if you're getting a high end cpu though, i'd always get an after market cooler for it... just for the peace of mind. its only 20$ or so for a cooler which performs a ton better than stock.
https://linustechtips.com/topic/215412-too-hot/#findComment-2955886
