Posted September 14, 2014 I'm looking to replace my rear 140mm exhaust with something quieter...and I'd prefer to not have to control it (i.e. I'd rather just run it at 100%). Would something like this look good, or would it be too much? I'm thinking its going to be too much, but I'm not sure.http://www.newegg.com/Product/Product.aspx?Item=N82E16835553015&ignorebbr=1 /Also, are there any other recommendations? It's going to be visible so it needs to be black and/or blue. As well as be very quiet. I was also looking at AF140's but the non-LED version is $8 more than the LED version, and according to the db rating, neither ar super quiet--although...I dont really put much faith in those readings since they seem like they're incredibly inaccurate. PSU Tier List | CoC Gaming Build | FreeNAS Server Spoiler i5-4690k || Seidon 240m || GTX780 ACX || MSI Z97s SLI Plus || 8GB 2400mhz || 250GB 840 Evo || 1TB WD Blue || H440 (Black/Blue) || Windows 10 Pro || Dell P2414H & BenQ XL2411Z || Ducky Shine Mini || Logitech G502 Proteus Core Spoiler FreeNAS 9.3 - Stable || Xeon E3 1230v2 || Supermicro X9SCM-F || 32GB Crucial ECC DDR3 || 3x4TB WD Red (JBOD) || SYBA SI-PEX40064 sata controller || Corsair CX500m || NZXT Source 210. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 Uh how the heck would it be too much? Make it as blue as you like. Too many ****ing games! Back log 4 life! :S Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 If that'd be mine rig, I would say that there's enough blue (your rig looks awesome btw), but if you want even more blue, THROW SOME MOAR BLUE!!!! BRING ON THE BLUE!!!!!! I think that a non-LED version AF140 in the back with a blue ring would look really sharp, so I vote for non-LED fan in the back. Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB @ 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6 Laptop: 2018 Apple MacBook Pro 13" -- i5-8259U | 8GB LPDDR3 | 512GB NVMe Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+ Display: Gigabyte G34WQC Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 You can get this fan this work just great it better with airflow and it comes to 140/120mm LED fans http://www.newegg.com/Product/Product.aspx?Item=N82E16835345038 Dimensions (mm) 140x140x25mm Current (A) 0.18A ±10% Speed (RPM) 1200 RPM ±10% Air Flow (CFM) 86.73 CFM ±10% Air Pressure (mmH2O) 1.38 mmH2O Noise (dB-A) 22.8 dB(A) But honestly it your case look to perfects with the right amount of lighting but if you over do it can look ugly like some youtube videos that over do it end up making it looking bad Be careful all I'm saying If I was you I would just get Corsair AF140 quiet edition (not led edition) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 You can get this fan this work just great it better with airflow and it comes to 140/120mm http://www.newegg.com/Product/Product.aspx?Item=N82E16835345038 Please no. As blue LED case fans Spectre Pros are terrible "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 I'm looking to replace my rear 140mm exhaust with something quieter...and I'd prefer to not have to control it (i.e. I'd rather just run it at 100%). /Also, are there any other recommendations? It's going to be visible so it needs to be black and/or blue. As well as be very quiet. I was also looking at AF140's but the non-LED version is $8 more than the LED version, and according to the db rating, neither ar super quiet--although...I dont really put much faith in those readings since they seem like they're incredibly inaccurate. http://www.newegg.com/Product/Product.aspx?Item=N82E16835553015 "Rawr XD" Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 Author Uh how the heck would it be too much? Make it as blue as you like. There can most definitely be too much blue. If that'd be mine rig, I would say that there's enough blue (your rig looks awesome btw), but if you want even more blue, THROW SOME MOAR BLUE!!!! BRING ON THE BLUE!!!!!! I think that a non-LED version AF140 in the back with a blue ring would look really sharp, so I vote for non-LED fan in the back. -snip- Thats what I was thinking, but looking at noise ratings it's quite loud. (But as I said in my initial post, I don't know how much stock to put in that rating since they don't really seem to be all that accurate). You can get this fan this work just great it better with airflow and it comes to 140/120mm http://www.newegg.com/Product/Product.aspx?Item=N82E16835345038 Saw that, but its more than the Cougar and it's supposedly louder. Please no. As blue LED case fans Spectre Pros are terrible http://www.newegg.com/Product/Product.aspx?Item=N82E16835553015 Any particular reason why? PSU Tier List | CoC Gaming Build | FreeNAS Server Spoiler i5-4690k || Seidon 240m || GTX780 ACX || MSI Z97s SLI Plus || 8GB 2400mhz || 250GB 840 Evo || 1TB WD Blue || H440 (Black/Blue) || Windows 10 Pro || Dell P2414H & BenQ XL2411Z || Ducky Shine Mini || Logitech G502 Proteus Core Spoiler FreeNAS 9.3 - Stable || Xeon E3 1230v2 || Supermicro X9SCM-F || 32GB Crucial ECC DDR3 || 3x4TB WD Red (JBOD) || SYBA SI-PEX40064 sata controller || Corsair CX500m || NZXT Source 210. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 There can most definitely be too much blue. Thats what I was thinking, but looking at noise ratings it's quite loud. (But as I said in my initial post, I don't know how much stock to put in that rating since they don't really seem to be all that accurate). Saw that, but its more than the Cougar and is supposedly louder. Any particular reason why? Really, you pretty much never can trust noise ratings, and the Quiet Edition fans aren't actually loud... If you want them even quieter you could undervolt it anyways, all of their fans come with an in-line resistor. Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB @ 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6 Laptop: 2018 Apple MacBook Pro 13" -- i5-8259U | 8GB LPDDR3 | 512GB NVMe Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+ Display: Gigabyte G34WQC Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 My personal taste is that colored LED destroys the rig. You have white LED (which is good) so I would take the non LED version with the blue ring (but it is more expensive) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 no look at my pc My Setup Spoiler Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 I'm looking to replace my rear 140mm exhaust with something quieter...and I'd prefer to not have to control it (i.e. I'd rather just run it at 100%). Would something like this look good, or would it be too much? I'm thinking its going to be too much, but I'm not sure. http://www.newegg.com/Product/Product.aspx?Item=N82E16835553015&ignorebbr=1 /Also, are there any other recommendations? It's going to be visible so it needs to be black and/or blue. As well as be very quiet. I was also looking at AF140's but the non-LED version is $8 more than the LED version, and according to the db rating, neither ar super quiet--although...I dont really put much faith in those readings since they seem like they're incredibly inaccurate. Ignore db ratings, corsair fans are all pretty loud compared to actual good fans. If you want a good blue fan, get the AP123. CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 Uh how the heck would it be too much? Make it as blue as you like. You can over do it, especially with blue. CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 Hmmm, am I really the only one that just goes for permance and doesn't give a crap how my pc looks? Maybe i should try to make an extra ugly PC on my next build. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 Cougar is great when it comes to fans, I've never used one of their LED fans, so I can't speak about them, but build quality is excellent, as is the noise level. INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550WSAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 Author Cougar is great when it comes to fans, I've never used one of their LED fans, so I can't speak about them, but build quality is excellent, as is the noise level. I have some cougar vortex 120mm pwm fans, but I don't find them all that quiet. At 1000~ rpm they're reasonable. I think I'm leaning more towards the AF140s as I think they'd look the best...but, I hear so many mixed things about Corsair fans. PSU Tier List | CoC Gaming Build | FreeNAS Server Spoiler i5-4690k || Seidon 240m || GTX780 ACX || MSI Z97s SLI Plus || 8GB 2400mhz || 250GB 840 Evo || 1TB WD Blue || H440 (Black/Blue) || Windows 10 Pro || Dell P2414H & BenQ XL2411Z || Ducky Shine Mini || Logitech G502 Proteus Core Spoiler FreeNAS 9.3 - Stable || Xeon E3 1230v2 || Supermicro X9SCM-F || 32GB Crucial ECC DDR3 || 3x4TB WD Red (JBOD) || SYBA SI-PEX40064 sata controller || Corsair CX500m || NZXT Source 210. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 no My Rig PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksYPrice breakdown by merchant: http://ca.pcpartpicker.com/p/kGNksY/by_merchant/ CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor ($379.00 @ shopRBC) CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler ($34.99 @ NCIX) Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard ($78.83 @ DirectCanada) Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory ($139.99 @ Memory Express) Storage: Kingston Fury 120GB 2.5" Solid State Drive ($71.34 @ DirectCanada) Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($92.95 @ Vuugo) Video Card: Gigabyte Radeon R9 280X 3GB Video Card ($298.98 @ Newegg Canada) Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case ($125.98 @ Newegg Canada) Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply ($66.99 @ NCIX) Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($116.00 @ shopRBC) Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm Fans ($23.99 @ NCIX) Monitor: HP 22xi 60Hz 21.5" Monitor ($187.11 @ Amazon Canada) Monitor: HP 22xi 60Hz 21.5" Monitor ($187.11 @ Amazon Canada) Keyboard: Logitech G710 Wired Gaming Keyboard ($114.99 @ NCIX) Mouse: Razer DeathAdder 2013 Wired Optical Mouse ($76.99 @ Amazon Canada) Headphones: Kingston HyperX Cloud Pro Headset ($78.98 @ DirectCanada) Total: $2074.22 Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100 Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0 Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2014 I've had good luck with Antec and Bitfenix. Antec - LED is not as dull as pic makes it look. http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16835209057&cm_re=140mm_LED_Blue-_-35-209-057-_-Product Bitfenix http://www.newegg.com/global/uk/Product/Product.aspx?Item=N82E16835345018&cm_re=140mm_blue_led-_-35-345-018-_-Product [Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16 [GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850 [Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 3x 120mm Corsair LL RGB Theater Room - My 11.1 Home Theater Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2014 Got these Corsair SP120 Green LED 120mm ones as the dual kits were on discount for the price of one, and they are quieter than the original Antec case fans. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
