Korean Monitor Power Cables
Solved by W-L,
I was looking at getting a Korean 2560 x 1440 monitor.I was looking at a few on Ebay, but I noticed they use that Korean power cable. I understand it connect to the display with the same standard power cable as anything else. I was wondering if it would be okay to just use the standard American power cable and outlet or would I have to fiddle around with something to power this thing without frying it?
Tried searching through post but haven't seen anything about this.
Check the input power specs on the monitor most monitors and PSU are dual power so it can take 120/240V via a switch or auto-switch but just take a look to be sure before hand.
If it's a straight 220V you'll need a transfer to convert the 120V to 220V.
