Gpu Card
Go to solution Solved by Enderman,
yeah my bad is an R9 290 enough for like gta or bf4
yes
Did you mean a gaming PC?
 I don't think 'gaming cpu' is a real thing...
https://linustechtips.com/topic/207779-gpu-card/#findComment-2818676
I'm assuming you mean gaming computer, not CPU. They don't really make 'gaming' CPUs.
Generally you only need one, but it really depends on what GPU you get.
I actually couldn't underclock my 5 year old GPU to make it as slow as a next-gen console.
#pcmasterraceproblems
~Slick
https://linustechtips.com/topic/207779-gpu-card/#findComment-2818698
yeah i meant pc im kind of tense sorry, so is 2 neccesary to play games like gta 5
It depends what GPU you're getting.
~Slick
https://linustechtips.com/topic/207779-gpu-card/#findComment-2818703
yes
https://linustechtips.com/topic/207779-gpu-card/#findComment-2818727
Yes that's good enough. You definitely don't need two of them, just one.
~Slick
https://linustechtips.com/topic/207779-gpu-card/#findComment-2818731
