            Hi there everyone! So this is my first post, so I'm sorry if I did something wrong. Aside from that, I am spending money to build my first computer and want to make sure that I am getting everything right. Over the next few months, I will earn 1400 dollars, so that will be my budget. My goal is to build it by Christmas time, so I would love to know if there is any other new hardware coming out by then. This computer will be used for about 85 percent gaming, the rest either normal school use, and very minimal amounts of video editing, but I don't want that to be a factor. So that's about it, and here is my build.
Processor:
Intel Core i7-4790K Haswell 4.0 GHz LGA 1150
Mobo:
ASUS Sabertooth Z87 LGA 1150 Mark 1
GPU:
EVGA Superclocked 02G-P4-2765-KR GeForce GTX 760
RAM:
HyperX Fury 8GB DDR3 1866 240 Pin
Hard Drive:
Western Digital Green 2TB 64MB Cache 6.0Gb/s
WITH an Intel 530 series SSD 240GB SATA 3
Operating System:
Windows 8.1 64-bit-OEM
DVD Burner:
Samsung DVD Burner Model SH-224DB/BEBE
CPU Cooler:
Cooler Master Hyper 212 EVO
Wireless Network Adapter (PLEASE let me know if you know of any alternatives, I don't have ethernet in my room....):
PCI Wireless WiFi Network card adapter 300Mbps 802.11b/g/n + Antenna
Case:
Corsair Obsidian Series 450D Black ATX Mid Tower
So that's my build! As I said before, PLEASE let me know if you have any suggestions!
So....... I suppose I should put something here....
https://linustechtips.com/topic/207154-first-build/
I would get an I5, Z97, cheaper mobo and a 780.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/207154-first-build/#findComment-2810774
4690k, Z97, better GPU
also instead of getting a wireless adapter, buy a motherboard which has built-in wifi.
https://linustechtips.com/topic/207154-first-build/#findComment-2810783
Drop CPU to i5 4690K, bring up motherboard to MSI Z97 MPOWER or Z97 Sabertooth Mark 1 and get a GTX 780 or R9 290. You will also need a PSU, which I would recommend the EVGA SuperNova G2 750W or Rosewill Capstone 750 M
https://linustechtips.com/topic/207154-first-build/#findComment-2810786
Haswell refresh processors should be used with a Z97 board instead of Z87. I would really think about the build when you have the money because factors about the build will probably change by the time you have it.
As for critiquing it right now:
i5 4690k, Z97, a 280x, WD Blue drive, 840 Evo instead.
As for networking, you can try a powerline adapter instead of wireless.
https://linustechtips.com/topic/207154-first-build/#findComment-2810791
Looks ok however maybe putting a GTX770 in instead and going for a i5 4790k is a better idea (your choice). Also I would definitley get an external optical drive because that case looks god awful with the optical bays used. Also you might want to look at an SSHD instead of the 2TB Green (if not, go for a red).
https://linustechtips.com/topic/207154-first-build/#findComment-2810798
@mrGOAB,
A number of suggestions. As others have mentioned an i5 is sufficient for gaming and a better gpu would make a big difference. I would also suggest a Z97 motherboard with on-board WiFi, less expensive memory, a newer model ssd, a better performing hdd, and better psu.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($234.67 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($29.99 @ Micro Center)
Motherboard: Asus Z97-PRO(Wi-Fi ac) ATX LGA1150 Motherboard  ($198.98 @ SuperBiiz)
Memory: Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($79.99 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($109.99 @ Amazon)
Storage: Toshiba  2TB 3.5" 7200RPM Internal Hard Drive  ($74.99 @ Micro Center)
Video Card: Gigabyte Radeon R9 280X 3GB WINDFORCE Video Card  ($269.99 @ NCIX US)
Case: Corsair 450D ATX Mid Tower Case  ($109.99 @ Newegg)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($83.98 @ OutletPC)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer  ($14.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.99 @ NCIX US)
Total: $1297.55
Generated by PCPartPicker 2014-08-30 22:30 EDT-0400
https://linustechtips.com/topic/207154-first-build/#findComment-2811685
Hi there mrGOAB,
for a gaming build I could advise you to check out the WD Black hard drive. It has big capacity up to 4 TB, 7200 RPM and was designed as a maximum performance drive for gaming and more demanding applications. The WD Green drive on the other hand, would also do a great job, but it's mostly used as secondary storage for archiving and backuping. It has IntelliPower; special power management, quiet performance and reduced heat output, which makes it more reliable and soundless, but could also make it lack fast enough speed when too demanding programs and games are active.
The RAM and CPU are very good. Though, you could look into a smaller processor. If you want to overclock, then the CPU Cooler is a nice choice. Have you considered a liquid one? You could look into those as well.
WD Black:
http://wdc.com/en/products/products.aspx?id=760
Best of luck! :)
CK_WD
If you think I helped, like!  :P
www.wdc.com
https://linustechtips.com/topic/207154-first-build/#findComment-2820950
