The temperature is quite high so it's hot, which means I'm hot.
But because it's hot I'm all sweaty and disgusting so I am not hot.
I'm hot and not hot at the same time. Wow.
The stone cannot know why the chisel cleaves it; the iron cannot know why the fire scorches it. When thy life is cleft and scorched, when death and despair leap at thee, beat not thy breast and curse thy evil fate, but thank the Builder for the trials that shape thee.
https://linustechtips.com/topic/202869-its-hot/
the only way i would sweat is if i have my hand going in a certain motion for a period of time  :ph34r:
Space Journal #1: So Apparently i  was dropped on the moon like i'm a mars rover, in a matter of hours i have found the transformers on the dark side of the moon. Turns out its not that dark since dem robots are filled with lights, i waved hi to the Russians on the space station, turns out all those stories about space finding humans instead of the other way around is true(soviet Russia joke). They threw me some Heineken beer and I've been sitting staring at the people of this forum and earth since.
https://linustechtips.com/topic/202869-its-hot/#findComment-2753464
Sooo, you work out with a dumbbell with one hand while surfing the web, right? At least That's what I do when I lock my room's door and try not to make too much sound for a few hours.
https://linustechtips.com/topic/202869-its-hot/#findComment-2753501
https://linustechtips.com/topic/202869-its-hot/#findComment-2753504
yup, I will agree to that.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/202869-its-hot/#findComment-2753526
Just replace the beer bottle with something else...
i dont drink. im just naturally loopy  :P
https://linustechtips.com/topic/202869-its-hot/#findComment-2753537
Welcome to global warming!  :P
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
https://linustechtips.com/topic/202869-its-hot/#findComment-2753547
Look at your picture :P
you see nothing  :ph34r:
https://linustechtips.com/topic/202869-its-hot/#findComment-2753560
Still cooler than last year. also if you didnt get the liberal notice, they changed it to climate change.
https://linustechtips.com/topic/202869-its-hot/#findComment-2753563
