Radeon r5 230 wont work !
razoku
Hey guys , so i bought an graphics card to switch my integrated motheroard graphics .
And when  put it in my rig an ran it , notin , black screen , tried 3 times .
Went to store , worked perfectly on their rig .
 had an last graphics card nvdia gt 630 ,shoud i delete its drivers  and if so , how ?
Or what do i do ?
I deleted nvidia drivers , installed it , and nothing , im soo desperate pls help
Is the GT 630 just a small bit weaker?
"If violence does not work, try more violence"
Have you plugged it in properly? It makes no sense for it not to work as the GT 630 is more power hungry. Drivers don't matter, they are inside the OS and you should just get a low ressolution when there are no drivers.
Did you go into the BIOS and change the the video output?
Setup: i5 4670k @ 4.2 Ghz, Corsair H100i Cooler, Corsair Vengeance Pro 16GB Ram @ 1600 Mhz, MSI Z87-GD65 Motherboard, Corsair GS700 2013 edition PSU, MSI GTX 770 Lightning, Samsung EVO 120 SSD + 2TB&1TB Seagate Barracudas, BenQ XL2411T Monitor, Sennheiser HD 598 Headphones + AntLion ModMic 4.0
Or what do i do ?
Try the 230 in another system (a friend's system if you don't have another system on hand) to check if it's the problem...
I didn't even know AMD had a R5 series gpu
it even worst than the R7 240 :P
but OP didnt you follow my steps and reset the BIOS?
if you are still not sure post a picture of your system and we can tell you where to go
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
That's a whole new level of low end sorcery
