Running 1440p at 120hz with HDMI to displayport cable
Solved by Glenwing,
Thanks, that actually helps. So I would be able to run 1080 120hz using a signal converter box? (DVI graphics card to DP monitor).
Yes, but they are quite expensive. You need a DP to Dual-Link DVI converter.
Featured Topics
DaveNoir ·
Posted in Troubleshooting0 -
PietervdWiel ·
floris.rodedio ·
Posted in CPUs, Motherboards, and Memory1 -
Tamgam12 ·
Posted in New Builds and Planning2 -
LeGreatMaxiking ·
Posted in New Builds and Planning6 -
ShotTequil ·
Posted in Audio0
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
