Running 1440p at 120hz with HDMI to displayport cable
Solved by Glenwing,
Thanks, that actually helps. So I would be able to run 1080 120hz using a signal converter box? (DVI graphics card to DP monitor).
Yes, but they are quite expensive. You need a DP to Dual-Link DVI converter.
Featured Topics
opi3636 ·
Posted in CPUs, Motherboards, and Memory10 -
jordanbuilds1 ·
14
5
11
Fluuwu ·
Posted in Cases and Mods6
