1. Budget & Location
$CAD = 300. I want the best I can get for $300.
2. Aim
Play some AAA game even in lowest possible graphics (as long as there is no lag).
3. Monitors
I don't know what monitor I have but I currently have 1440x900 screen resoulution
4. Peripherals
I have some old stuffs, so I don't need any.
5. Why are you upgrading?
I need to replace my 10years old xp machine.
Thanks
https://linustechtips.com/topic/192772-need-help-for-my-build/
Do you have a current computer at all ( something that could be used for just it's HDD or case?)
If you can post some pics or link your Xp machine we can take the money for the case off the build price and get better parts.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/192772-need-help-for-my-build/#findComment-2612713
What will it be used for?
he say gaming at the lowest setting possible
he has a XP machine if you see his first post
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/192772-need-help-for-my-build/#findComment-2612719
For that price I'd buy a used Xbox One...and use it with the monitor...
Then save up when you get a job for a decent computer.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/192772-need-help-for-my-build/#findComment-2612728
CPU: AMD 5350 2.05Ghz Quad-Core Processor  ($62.99 @ NCIX)
Motherboard: Asus AM1M-A Micro ATX AM1 Motherboard  ($41.69 @ DirectCanada)
Memory: Crucial Ballistix Elite 8GB (2 x 4GB) DDR3-1600 Memory  ($79.09 @ Amazon Canada)
Case: BitFenix Comrade ATX Mid Tower Case  ($39.99 @ NCIX)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Memory Express)
Total: $323.70
Generated by PCPartPicker 2014-08-05 23:11 EDT-0400
over budget but will be good
https://linustechtips.com/topic/192772-need-help-for-my-build/#findComment-2612759
Not a very good system. If your old case and hdd could be used a better system might be possible.
CPU: Intel Pentium G3420 3.2GHz Dual-Core Processor  ($74.75 @ Vuugo)
Motherboard: ASRock H97M Micro ATX LGA1150 Motherboard  ($42.90 @ Amazon Canada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Canada Computers)
Case: Xion XON-720P_WT MicroATX Slim Case w/300W Power Supply  ($39.99 @ Amazon Canada)
Total: $291.72
Generated by PCPartPicker 2014-08-06 01:18 EDT-0400
https://linustechtips.com/topic/192772-need-help-for-my-build/#findComment-2613498
