Sound Card + DAC/Amp recommendation?
Solved by ShearMe,
what do you mean by better connectors?
The Monoprice unit has more connectors for various uses, plus they are more durable.
Also, If I have speakers plugged into the DAC, is it easy to switch back and forth between speaker/headphone output?
There is no switch. The outputs continuously transmit a signal. Only way to "switch" is to turn the speaker system on and off.
Seosamh_101 ·
Posted in Windows2 -
2
1
2
3
ShayOh ·
Posted in Troubleshooting2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
