NZXT Kraken X61 or swiftech h220x
Go to solution Solved by Enderman,
x61 performs better for sure.
which preforms better?
and are they compatible with the thermaltake core v71?
thx :)
They both are compatible, personally I would only get the h220x if you're seriously considering expanding the loop, otherwise if not the x61 is just a more compact and cleaner look if your just going to have a cpu stand alone loop
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
Why do you say this. Linus did a video on the h220x and cpu temps were significantly lower.
You either need some glasses or you watched that video with your eyes closed...
thx  thats all i needed to know
This is because its a 280mm rad compared to the 240mm rad from swiftech. It should be better.
Yup
Plus its a thicker rad too
is there any 400 mm rad?
