Not sure if i am impulse buying, or not.
Thebman712
So latley when ever i get a idea that seems cool to me, or if i did something i think seems cool, i always want to invest in/ buy my own gear.
Now that seems like impulse buying for sure, but before i want to buy anything i have to go and research what is good and what to buy, which makes me think weather to get it or not.
I usually think that it is still a good idea and proceed to the point of almost buying. But i recently realized that my instinct to want the item is clouding my judgement.
So the most recent time this happened was with paintball. I was at a pAintball camp for 2 days and had lots of fun and i want to do it more, i think i could make a real hobby out of it. But i am not sure how often i would be able to go, and if the investment of it is worth it.
I think that recently i have been kinda discouraged by hockey and am looking for a replacement sport. So i think that could be clouding my mind too
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
I impulse buy a lot of things.
On my first paycheck I bought a $200+ watch and a hundred dollars worth of candy, even though I wanted to save up for a PC
When I got hired at Tim Hortons, I immediately went and borrowed $120 from my brother so I could buy it.
They way I see it - If I enjoyed buying something and I think I got enjoyment out of it, it's not money wasted.
INTEL CORE I5 4670K | NVIDIA GTX 980 | NOCTUA NH-L9i | GIGABYTE GA-Z97X-SLI | KINGSTON 120GB V300
CM STORM QUICKFIRE TK | BENQ XL2420TE | ROCCAT SAVU | FRACTAL DEFINE R4
But.. It's your own money, so you have to decide whether to spend it, If it brings you any happiness sure,
Details separate people.
yea i relise that but i need to know weather its impulse buying
My Rig
Total: $2074.22
Paintball can be alot of fun, but it is a very expensive sport if you succumb to gear lust easily. I would say don't buy a gun more expensive than an auto-cocker (brand), they are without a doubt the best guns on the market, don't go for the "automatics" because they suck, your better off being accurate. Also the auto-cockers have the best range because they fire from a closed bolt instead of an open bolt.
Dubs are better than subs
I would only consider impulse buying a problem if you frequently regret buying the things that you bought. If you enjoy the things you buy and you continue to enjoy them later, then what does it matter if your decision making process was impulsive?
In the case of paintball equipment, you'll probably want to just stick with renting equipment (if it's reasonably affordable) until you have enough experience to know whether or not you want to buy your own set and continue playing.
i7 not perfectly stable at 4.4.. #firstworldproblems
im getting a 225$ Gog enmey setup if i do, and i have a membership to my field so i get discounts
My Rig
Total: $2074.22
Probably is , you can save up & get a better one later on ,
about paintball , a quite good research is going on (as they did with occulus) it's kinda like a suit that makes you know you've been hit & hurt , without the actual hassle of real paint ball You can go for this future tech if you save up, by then you can have best of both worlds..Just sayin, But it's your choice , you can have the same thing now
i have prob over 20 hours of play tine so i know if i like it and if i want to continue playing, which i do i just dont if it is feasible money wise
My Rig
Total: $2074.22
yeah that sounds like it would be quite a few thousand $ more than i will likely every spend on paintball
My Rig
Total: $2074.22
Walked into a Frys today at lunch. Saw a triple monitor stand and just bought it :P
Case:Define R4 | MOBO:ASRock z75 Pro 3 | CPU:i7-3770k 4.0GHz | CPU Cooler:H100i | GPU:970 Strix | RAM:Hyper X 16GB |
Peripherals:ATH-M50x Limited Blue Edition | K95 RGB | M65 RGB | Blue Yeti MIC | (3x)1920x2080 Acer Monitors
All I'm saying is auto-cocker's are the absolute best, bar none. Their closed bolt system offers greater accuracy and range than any other paintball gun (I hate it when people say marker just to avoid saying the word gun). Although they don't perform quite as well with CO2 because they use their air to actuate the action. Still, if it's not closed bolt, it's inferior. Auto-cocker makes a decent lower end gun, the trilogy series was like 150$ when I got mine (last I looked, been a long time since I was into paintball though). Check em out before you buy.
Don't focus on how fast you can fire the gun and still have paint come out, that's a rookie mistake (for woodsball anyways, I ignore the speedball people because it's less fun and more expensive). Look at accuracy and range.
Definitely find a way to do Compressed air over co2, far cheaper. although if I remember correctly some fields will only allow you to use nitro or co2.
yeah im going hpa in my setup and my field does not do co2 refills only hpa
My Rig
Total: $2074.22
That's something that only you would be able to figure out, because you're the only one who knows both your exact income and expenses.. In terms of blunt common sense, if you can afford to buy the equipment you want and still be able to pay food/rent/etc(the necessary stuff), then I'd say that it would be feasible..
Personally, I threw all of my numbers into an excel document, so I have a specific amount of money directly allocated towards frivolous expenditures. It doesn't matter if an expense is impulsive if there's money allocated towards impulsive buys.
yeah as 13 year old (until the 7th then 14) so i dont really have a exact wage, i get paid by how many hours i officiate buy. I dont have to pay those other things just have to save up for things like a laptop and a car
But i could be able to afford paintball but i may not be able to save as much as i would like
My Rig
Total: $2074.22
i cant even find a cocker on the gog enmey, its newer so you may not have heard about it
My Rig
Total: $2074.22
