Has anyone ever experienced this?  I normally have a wallpaper but lately it's been disappearing and my background has turned black.  There were also black squares around icons on my desktop and if I moved them around on my original desktop wallpaper it would create a black square where it went.
Case: NZXT H500i. Motherboard: Asus Prime Z390-A. CPU: i7 9700k OC @ 5.0GHz. GPU: EVGA 2080 FTW3 CPU Cooler: NZXT X62. Memory: G. Skill Ripjaws 32Gb 3200mhz. Storage: 1TB Samsung 840 EVO SSD /  120GB Samsung 840 EVO SSD  /  WD Caviar Black 3TB / WD Caviar Green 4TB. . PSU: Corsair AX760. Monitor: 2x Acer XB270HU. Keyboard: Corsair K70 RGB. Mouse: Corsair Glaive.
https://linustechtips.com/topic/189702-why-does-my-desktop-keep-going-black/
what gpu do you have I had this problem and just did a clean driver install and it solved it :D
CPU 5900x| GPU 3080ti FE| MOBO MSI MPG CARBON MAX| RAM 32GB VENGENCE PRO 3200Mhz| STORAGE Samsung 980 Pro 1TB,2X WDSN750,4TB Seagate Barracuda| COOLING 1x Corsair 360mm XR7 54mm Radiator,1x EK-CoolStream PE 360mm Radiator| GPU Block: Corsair Hydro X Series, XG7 RGB| CPU Block: Corsair Hydro X Series, XC5 RGB| Fittings: EK-Torque STC & Corsair Hydro X Series XF| Pump/Res: EK-Quantum Kinetic TBE 300 D5| Tubing: Corsair Hydro X Series XT Softline| Liquid: Corsair Hydro X Series XL5 Clear| Fans: 10x Corsair SP120 RGB
OS?
When was the last time you did a clean isntall?
Look at his sig
Cause once you go black you never go back
On a more serious note, make sure that you have correct graphics drivers, and that your OS is a genuine install.
"Rawr XD"
Look at his sig
haha dident see it the first time I looked ;D tucked in on the end of his sig there
780ti.  You know, I just installed the new Nvidia driver and that's when it started.  That must be it!
I had some problems this morning and I updated last night to the new nvidia driver
OS?
I think it might be the new Nvidia driver that came out.  Now that I think about it that's when it started.
Downgrade then to the one where everything worked :)
Probably GPU driver and in Windows 7 if you don't activate your OS the wallpaper will go black all the time.
Wait, what?  I have Windows 8.1 pro.  How do I do what you just mentioned?  Sorry, I'm still getting used to Windows.
Did you buy Windows from a store/online or did you pirate it?
I bought it from a store. G2a
If it started after the driver update, then it's probably the driver acting goofy. Roll back to the last one that worked.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
