If my front fan is meant to intake air and both the rear and top fans are meant for exhaust, then how is positive airflow even possible in a regular case unless I install fans on the side and in the bottom of the case or switch the top rad fans to intake? So many people swear by positive airflow, yet it isn't even able to achieve more intake fans than exhaust fans unless you force cold air down the top of the case instead of letting hot air rise. In most cases there is only room for 1 front intake, 1 rear exhaust and 2 top exhausts, making the air pressure negative.
Have you tried turning it off and on again?
https://linustechtips.com/topic/186359-positive-air-pressure/
Make the rear exhaust an intake so you have neutral pressure.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2507107
Also make sure that all your intakes are filtered otherwise positive airflow is useless.
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2507114
what @tmcclelland455 said, and i might be wrong but don't cases usually have 2 front fans slots? That's the kind of image i have
CPU: Intel i7-4770k MOBO: Asus Maximus VI Formula RAM: G.Skill RipJawsX 2x8GB 1600Mhz GPU: Asus GTX 780 DCuII CASE: Phanteks Enthoo Primo STORAGE: ADATA SX900 256GB / WD Caviar Blue 1TB PSU: Corsair AX760 760W MONITOR: Dell Ultrasharp U2312HM KEYBOARD: Ducky Shine 3 MOUSE: Logitech G602 http://linustechtips.com/main/topic/106614-project-insert-name-enthoo-primo-rigid-acrylic-red/
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2507115
something to ponder:
if you use an air filter on the intake fans, it suddenly reduces the amount of air
brought into the case. if fans are the same..
2 filtered fans and two exhaust fans is still a negative pressure scenario
3 filtered fans and two exhaust fans is still going to be a negative pressure course.
can pretty much count on 4:1 to make an equalize pressure case
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2507317
Just amount of fans doesn't make anything. If you truly want to know what airpressure your case has, you need to know CFMs for both intake and exhaust fans. So basicly you can modify airflow in cases that have limited mounts for fans. Like make intake have more CFM by running them full speed or higher speed than exhaust ones.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2508848
Positive or negative air pressure is about total intake CFM vs total exhaust CFM. Two 140's intake vs two 120's exhaust, would generally mean higher intake CFM. Most cases I've looked at have 2 or more front fan mounts, 1 or 2 bottom fan mounts, 2 top fan mounts and 1 rear fan mount. This is more enough flexibility to setup positive air pressure.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2509899
might be helpful:
http-~~-//youtu.be/4NYHC3DXynM
This :-)
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2514901
This.
My case has very restrictive filters (I added carbon filters from an air purifier) and I have 4*120 intake, and 2*120 exhaust and dust gets in, not though the filters tho, the slight negative pressure.
https://linustechtips.com/topic/186359-positive-air-pressure/#findComment-2516469
