https://linustechtips.com/topic/185694-best-way-to-learn-lua/#findComment-2497049
you are buying a mechanical keyboard to learn lua?
https://linustechtips.com/topic/185694-best-way-to-learn-lua/#findComment-2497064
Play minecraft, computercraft is the way.
Exactly what I was going to say, you should really do this :P
Build log "Whiplash" : http://linustechtips.com/main/topic/158477-the-hero/
Whiplash: 4790k@4,4Ghz|Maximus VII Hero|4x4Gb Red/Black HyperX fury 1866Mhz|R9 290 Tri-X|Modded 450D|Sleeved cables on a M12II evo 850W|M500 480Gb| BenQ XL2411T@144Hz
Laptop: 4700MQ|16Gb@1600Mhz|Quadro 1100M|1080P|128Gb SSD|500Gb 7200RPM hdd
https://linustechtips.com/topic/185694-best-way-to-learn-lua/#findComment-2497251
This is actually a great idea. You can do so much in it that it is actually really scary. You can go on their wiki and see people who make fully graphical OSs for their computers in the game. (I recomend doing all your programming outside of the game though, since the in game editor looks nice and works, but lacks some useful features of doing it in say Notepad++.)
"Her tsundere ratio is 8:2. So don't think you could see her dere side so easily."
Planing to make you debut here on the forums? Read Me First!
unofficial LTT Anime Club Heaven Society
https://linustechtips.com/topic/185694-best-way-to-learn-lua/#findComment-2499696
Jup notepad++ is the way to go, ingame hasn't got syntax highliting (atleast back when I used computercraft) which is quite usefull ^^ is the way to go.
https://linustechtips.com/topic/185694-best-way-to-learn-lua/#findComment-2510055
Actually there is a program for ComputerCraft called luaIDE which does things like syntax highlighting. The thread on ComputerCraft forums is here. You can install it by typing: "pastebin get vyAZc6tJ luaide" Oh just to remember use this on an advanced computer otherwise colours won't work.
https://linustechtips.com/topic/185694-best-way-to-learn-lua/#findComment-2556064
