Posted July 15, 2014 Ok guys I have a major issue. Although not shown in any of the advertising pictures, the phobya 200mm has been updated to revision 2.0 which has a larger end tank and doesn't fit in the 600t anymore. I've rung around a few stores online and they all say they only have rev 2 in stock now. Any ideas? My one arrived today from special tech, and although they have been great and offered a refund, doesn't solve my issue. I need a 200mm radiator. Either that or I have to cut up my case which I'm not fond of. Spoiler Primary PC (Photo editing and gaming on a 4k Monitor): Intel I7 4790k @4.5ghz @1.2v | 24GB Corsair Vengeance Ram @1600Mhz | 1x Palit GTX 1080 JetStream| 480GB Crucial SSD | 2x WD Blue 500gb | Corsair RM1000 | Corsair 600t Secondary PC (Gaming and watching films on a 42" 4K LG IPS TV @4k60): Inteli7 4790k | Corsair H60 | Asus H81l-plus ITX | 16GB Kingston Hyperx Beast 1600MHz | 1x GTX 980 G1 Windforce| 1x Samsung 1 TB 850 EVO SSD |Corsair CXM750W | Coolermaster Elite 130 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 15, 2014 I had to just do pull with mine. Can't fit fans inside the case with the rad, just do either push or pull through the top fans or fan if you keep the 220mm. CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 15, 2014 Author I had to just do pull with mine. Can't fit fans inside the case with the rad, just do either push or pull through the top fans or fan if you keep the 220mm. I think you misunderstand me. The top rad is fine. I have installed a 200mm radiator with a 200mm bitfenix fan at the front. I've sorted it now anyway. Had to use a dremel to cut new holes lower down. There was no other way. Spoiler Primary PC (Photo editing and gaming on a 4k Monitor): Intel I7 4790k @4.5ghz @1.2v | 24GB Corsair Vengeance Ram @1600Mhz | 1x Palit GTX 1080 JetStream| 480GB Crucial SSD | 2x WD Blue 500gb | Corsair RM1000 | Corsair 600t Secondary PC (Gaming and watching films on a 42" 4K LG IPS TV @4k60): Inteli7 4790k | Corsair H60 | Asus H81l-plus ITX | 16GB Kingston Hyperx Beast 1600MHz | 1x GTX 980 G1 Windforce| 1x Samsung 1 TB 850 EVO SSD |Corsair CXM750W | Coolermaster Elite 130 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
