BF3 extreemly low FPS
Go to solution Solved by lx_srs,
I just reloaded my machine, and im having a little problem with BF3.
Windows update grabbed the AMD 11.5 driver (i think), and that worked great. I could push about 60FPS on med-high settings on my 6870. It did give me an error when starting saying that it recomended i updated the drivers.
I went to the AMD website and downloaded the recomended driver (14.04), but now it runs at a max of 5FPS. In MSI afterburner it shows the GPU is still at idle.
All other games (WOT, CS:GO, TF2, LOL ect) run just fine.
Any suggestions?
Go into the folder where the game is installed. Find the DirectX redistributable, and run it as administrator.  This works for me every time a game runs poorly.
Any suggestions?
~Judah
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/
Turn your IGPU off.
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2344851
64 man server? Your cpu might be strugglin
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2344857
Turn your IGPU off.
He doesn't have one, he's on the FX platform.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2344877
Any suggestions?
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2344884
This worked, thanks a ton
Anytime! Can you set my post to solved so future visitors can find out too?
EDIT: Noticed you already did.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2345301
This is going to sound like a really dumb question because it probably is a dumb question, I'm having exactly the same problem,
I'm trying to use your solution but I can't find the Directx Redistributable. I can find the directx folder, and then redist but where
am I supposed to go from there? Any help would be greatly appreciated, thanks :)
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2374273
E:\Origin\games\Battlefield 3\__Installer\directx\redist
Note that I installed BF3 on my HDD, I have my OS on an SSD. Your "games" folder is most-likely in C:\Program Files (x86)\Origin Games (Just program files if you have a 32 bit system.)
I am also having this problem, except I am getting less than 1FPS, more like 1FPM. This better work.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/175587-bf3-extreemly-low-fps/#findComment-2376138
