Hey all,
I've been throwing the idea around of building my first computer (although I likely will not actually do so until I desperately need a new one), and have been snooping around for components.
I noticed that Austin Evan's most recent personal build is based in the Fractal Define R4 case. Although it would be my first, I would like the build to be a long lasting and effective one (such as room to watercool multiple components and/or add a second graphics card later on in its life). People who have bought the Define R4 like the sizing, layout, styling, and sound solutions the case brings, but many of the wire management and hard drive locations have sounded inconsistent and a bit more difficult to manage for a new builder.
Can anybody with experience (either with this specific case or in general) vouch for this case or recommend a more practical one? I'm up for a challenge, but it still need to be doable with my zero experience.
To be completely honest, I have not really dived into the case market yet, so someone who could also simplify and explain major brands as well as their strengths/weaknesses would also be a huge plus for me.
https://linustechtips.com/topic/172140-case-good-for-beginner/
Hey all,
Buy any case you want. If there is a decent amount of room behind the motherboard tray you'll be able to wire it up decently well.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287682
Define R4 / Haf X / NZXT H440, H230 /  but the Haf X is my favorit lots of room, very good internal layout, support for Dual 200mm Rad on the Top, an Intake Fan for your Graphics cards, but the three are just awesome, and doesn't mean you shouldn't  check some other options
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287690
Thanks for the rep, are you saying that despite branding, each case is individual?
What I'm saying is you don't really need experience to build in a case. So, as long as its a decent case you'll be able to build in it--and the R4 is a good case.
PSU Tier List | CoC
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287697
All three look large and stylish- appreciate it.
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287704
yeah, room for even an extreme water loop once you got the hang of this kind stuff
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287714
IF YOU REALLY WANT SPACE FOR WATERCOOLING GO FOR CASELABS HUGE MONSTERS. But really if you are building your first computer don't go not water cooling directly as you are compiling your first components just build your own pc run it for about a year or so then decide if you want to water cool but if you are desperate buy a premade watercool loop like the corsair h110 or h100i for water cooling without the hassle of the possiblity to wet your shit. But in all seriousness get the case you think looks the best because watercooling shouldn't be the first thing you should think about when you are building you first computer fullstop
[spoiler=My Beast Rig Damocles]Case: Coolermaster Storm Stryker Motherboard: Asus x79 deluxe CPU: Intel I7 4960x @3.6GHz (soon to be oc) RAM: Kingston HyperX 64GB @2400MHz GPU: Nvidia Geforce GTX 770 (Gigabyte) @4GB PSU: Corsair RM1000 Fully modular CPUCooler: Corsair H100i Watercooling Storage: Seagate 2TB SV35.6 SATA 6GB/s 7200RPM 64MB 3.5"   x2  Sound: Creative Soundblaster ZxR sound card
This is my old pc which I am reamending to be a media server or a nas. Motherboard: Generic fujitsu CPU: Intel pentium G640 @2.8 GHz RAM: 4GB generic fujitsu memory PSU:  CPUCooler: Stock intel cpu cooler Storage:  Fujitsu MHZ2120BH @120GB, Soon to have a HDD for more storage.
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287717
i'd say the Corsair Carbide 200R or 300R
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287763
Fractal design arc midi r2 gets my vote, with lots of room, and support for watercooling if and when you want to go down that route.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287766
snip
It is mid tower though. So there is limited room for huge components.
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287838
Hey all
 I suggest Phanteks:Entho Pro, Corsair:C70, or sticking with the R4
Edit: R4 and H440 are silence optimised cases with pretty bad airflow it's the burden of the beast I don't recommend them for a beginner...
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/172140-case-good-for-beginner/#findComment-2287956
