PC won't turn on after new cpu cooler installation
first off if the T4 cooler slid around a little when you were putting it on, then it doesn't really matter, happens all the time.
secondly, if the CPU was ripped out when you tried to take the stock AMD cooler off then you may have damaged either the pins on the CPU or the Installation mount on the motherboard. Check both for visible damage if you are able to.
if you take the CPU back out check that all the pins are straight and that none are bent even slightly. If any are bent they you may be able to get away with just using pliers to straighten them again.
Another reason why this might have happened is that when your dad used a sharp knife to pry the cooler off the CPU it may have discharged (or subsequently charged) a current of electricity, known as static. If that is the case then it is most likely done and dusted I'm afraid.
hope this helped
