Trickle from CPU water block
You can't get all the air bubbles out whilst bleeding it right away, sometimes you have to let it come out on its own, and no amount of upside down case shaking will fix it.
After doing ~3 separate maintenances on my loop, after re-filling I always have an air bubble in the CPU and GPU block, that I CANNOT get out. After leaving the loop running for a few days it comes out on its own.
Try opening the top of the res, and turning the pump off & on and off again, with different speeds as well.
You can place your finger on and off the res hole to see if it helps as well.
Lays has the best advice!!!
It should clear over tme on its own...what I do after filling:
1. Tilt PC on every extreme angle imagineable with pump running at mid to high speed.
2. Pinch tubes in various locations to briely "restrict" flow (when you release listen to the bubbles that ome thru)
3. Tap Rez witha rubber handles pair of pliers lightly (also clears micro bubbles)
4. a few times a days reduce speed of pump and increase speed of pump
It can take up to a week or so to completely clear all trapped air, be patient, it should clear itself ![]()
How are your temps? If there pretty good, dont sweat it, keep going thru the steps outline above.
As for your Tube runs......guys he's got his CPU Block "unmounted" and hes WC'ing his Mobo !! (also crappy angled pic).....so naturally it looks a bit untidy....OP, dont worry about re-routing all the tubing, if thats what you found to be the most optimal, then stick with it let us know if the bubble clears ....it should ![]()
If its possible to leave your fill port "open" then do that as it will assist in clearing air ...(Looks like a Photon 170 Pump / rez combo same as I have. so just leave the top plug out until finished bleeding), I leave mine out for a week or so!!
Also for tube runs, my only rules:
1. Keep runs as short as possible
2. Try not to "cross" tubes
3. Where 90's are required (particularly input / output) off pump / rez, use 2 x 45's or better still 3 x 30's
