Set up your ventilation/cooling in the case properly for good airflow.  Pick out cases that are known to help with this.  Buy a psu by top brands such as Antec and Seasonic.  Make sure you maintain it properly cleaning out dust and what not that gets in the pc every so often.  Also the first sign of anything going wrong do not keep using it and deal with the issue right away.  Troubleshoot it immediately.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210507
Do a clean install every 1-2 years.
Use ccleaner.
Uninstall any crap you don't need/use.
Dust your PC with compressed air every 1-6 months.
Back up your files.
Make a system image repair disk.
Use a good antivirus.
Use chrome.
Enjoy your PC.
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210514
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210547
Tip #1
Don't F up
Don't click on suspicious links? Don't give out personal info to things you shouldn't, like a Nigerian princess or French gadget editor. Oh, and don't ever, ever eat s'mores over your PC while the covers are out.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210564
Upgrade it all the time with beefier and better parts over and over again :P
A gaming PC is not an investment it's a money pit.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210588
Make fun of all your friends who don't own an awesome computer.  Your e-peen levels will get insane.
Project Insomnia
CPU: Intel i5 4670K @ 4.6 GHz.   CPU Cooler: NZXT Kraken x40   Motherboard: ASRock Z97 Extreme6   Memory: Corsair Vengeance 8Gb.   Graphics Card: EVGA SC Geforce GTX 780 Ti   Power Supply: EVGA G2 850W   Case: NZXT H440
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210592
And make sure to get new parts the second they're out no matter how weaker or stronger they are. Yes, throw away an i5 for the new AM1 Athlons or get rid of your 8GB RAM for the newest iteration of 4GB RAM. DO IT! I command thee!
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210595
What are friends?
The angry flesh bags the live outside your sanctuary. They're worse than even the level 159 zombies in Runescape.
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210606
What are friends?
What do you mean? You've never seen them?
The little people that walk around dressed like royalty sipping tea, eating cake, playing board games, and laughing at your jokes.
Honestly, I can't get them to leave.
Error: 410
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210610
What are friends?
I'm following the rules of your signature.
post-80890-0-28315700-1402721365_thumb.p
Project Insomnia
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210612
Hello.I need help with my new gaming PC. I would like to know some tips, tricks, anything else to help me make sure that my gaming PC runs smoothly for long time... Please help and thanks
  • be patient - nothing ruins a good set of parts faster than an impatient assembler
  • only change one thing at a time - when tracking down problems or tweaking performance
  • don't go benchmark crazy - your mileage will vary and most of the time you won't notice the difference
  • pushing hardware to its max is fun and leads to credit card use - for longer lived components don't run things flat out
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210653
in short long run means keeping components clean & dust free , you should do maintenance atleast once a year ..
This means :
Cleaning your cases inside & outside(vaccum it) ,
Dust of components like hdd/ssd outer surface ,
the cooling fan from the stock or custom cooler it's guarenteed to accummulate dust . reccommend you do it like 6 months or so,
dusting the PSU off the dust bunnies & look for tiny any tiny ant farms inside the psu (happens)
reapply the thermal paste to the CPU & reseat components & dust off the empty slots.
remove dust from the keyboard between the keys,
dust can cake up in finstacks & radiator fins this can obscure airflow & raise temps significantly
cover up the monitor with the palstic bag it came in when you're not using it or going away for a while
Other stuff you can do is :
Get a good line interactive UPS so that the voltage is steady to the PSU instead of using a surge to wall (helps you overtime)
Upgrade your PSU to a gold standard if possible.
unplug optical drives that you dont use that often
cover up the open slots on the back to prevent dust from entering into the case (optioinal)
dont keep the GPU overclocked to max everytim , same goes for the cpu , Only when you needed.
Details separate people.
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210710
Didn't know those existed. Or is it after the stupid combat update? :P
Sucks for you
First one to do so, good job!
https://linustechtips.com/topic/166080-tech-tips-and-tricks/#findComment-2210744
