IPS panel or TN panel?
Solved by WoodenMarker,
Yes, the difference is noticeable between 60 and 120hz. For most, the difference between IPS and TN is more apparent.
The colors of the TN panel aren't utter crap but they don't compare well to any decent IPS display.
Unless you really need the extra frames, going IPS is generally better.
1
toxic_worper ·
5
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
1
Vibora ·
Posted in New Builds and Planning6
