Is a Paint brush a viable cleaning method?
Solved by Cubit481,
I don't want to pay for compressed air cans, and the dust filters on the Define r4 aren't 100% dustproof. (not that anything could be, without restricting airflow to the point of system failure)
i use paint brush to clean some of the components too...it can easily reach places...even the coolers on the gpu as well as heat sink...
Featured Topics
2
GreenLeaf ·
Posted in CPUs, Motherboards, and Memory2 -
Saad1402 ·
Posted in CPUs, Motherboards, and Memory4 -
8
sgreenberg ·
Posted in Networking2 -
2
VinSen ·
Posted in Troubleshooting5 -
2
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
