600$ Build with Monitor
Solved by Zeke_,
The AIO seems extremely overkill for a 65 watt CPU. I would save that money and use it for more storage and use a budget friendly air cooler. (I personally recommend the ID Cooling A400 which I'm using on a 65 watt CPU right now). Other than that, for your use case I think the build looks good but keep in mind that the RX 580 (While a great GPU) will probably not be supported for drivers a while into the future if you plan on using this build for a long while, so if you could stay within your budget and get something from the RX 5000 series that may be a better option. You didn't include prices in your config, but I am seeing used RX 5600XT's on ebay for around $130 USD.
