My CPU Water Block is too small for my motherboard
Solved by IkeaGnome,
37 minutes ago, GuiltySpark_ said:That makes far more sense than what I was thinking in my head.
Sometimes it's the simple solutions.
@Hunterrcrafter Could try zip ties first if you have that laying around. Use zipties to go through pairs of holes in a circle and tighten down evenly.
Something like this. As long as you've got the cpu fully under the cooler it'd be better than nothing. If you've got zipties laying around it's a free solution just to test the machine and play around with until you figure something more permanent out.
