Help with Video Rendering via Adobe Suite
Solved by Avocado Diaboli,
If you're at 1440p, you might want to increase the bitrate per YouTube's own recommended settings.
Estimating render times is tricky, because it always depends on what you're doing to the footage in the software itself. Simply re-encoding a video you've dragged onto the timeline isn't going to take as long as rendering a video where you've applied color correction or computationally expensive effects.
Also, on a side note, you don't need to render out your After Effects clips. You can just import After Effects files into Premiere Pro. It'll play them directly and you can save yourself the step of exporting the video file.
