How to make obs video quality better?
Solved by WereCat,
So this will use whatever is in the Stream tab which by default will be really bad
so you want to change that to HEVC (h.265) preferably with your GPU so for NVIDIA you will choose NVENC h.265 and for AMD there should be something like AMAF h.265.
MP4 is just a container it has nothing to do with quality. MP4 has a disadvantage that if your recording gets interrupted for example by random restart or something, the whole file will be corrupted. Something like .MKV should still work until that point though.
