How do i ensure im grounded and not damage my pc while working on it?
13 minutes ago, IR76 said:My bedroom has carpet flooring so if I want to work on my pc at my desk I need to ensure I dont damage my components with static so is it just as simple as buying this wrist strap but what would I attach it to?
Screw the PSU into the case to make good contact, plug PSU into wall socket but dont switch on, this will make a physical path for static buildup to flow through. Then attach wrist strap (to wrist at one end obvs聽) to anywhere on the case, this will ground you and the case and keep you static free, but this shouldn't fry any components, Linus did a video with Electroboom recently where they actively tried to destroy components with shocks much stronger than static shocks and found it VERY hard to
聽
EDIT: oh true, what @Average Nerd聽said about exposed ground, always forget other countries dont also have this
