NZXT Cam appears to be flickering?
Solved by Extra Juicy,
I’m having the exact issue and it’s nearly impossible to use. Used DDU, Revo Uninstaller, etc with no prevail. Running a 14900k and 4080S. Definitely a bug on NZXT’s end.
Edit: Found a fix. It’s an issue with VRR and Low Latency mode. Suggest you either change them in global settings to off or go into program settings and turn them off there.
Featured Topics
Merf01 ·
Posted in Power Supplies2 -
Shockboost99 ·
McLovinKarma ·
Posted in PC Gaming1 -
Itnozetr3 ·
Posted in Graphics Cards0 -
ecoid ·
Posted in Troubleshooting0 -
MugooMeister ·
Posted in Troubleshooting1
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
