Pc fan
Arun48477
Hello, recentst I got a case for my second pc:oversteel irridium and I am havong trouble with turning on the fan and the rgb in the front of the Case does anyone know how to get those on?
Case fans need to be connected to the motherboard. There should be 2 wires coming out of them. One for fan control and one for RGB control. Make sure both are connected.
As for the front RGB, check for any unplugged front panel connectors.
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
well out my fan comes one cable wich has two point one should go connect to the front rgb and the other i suppose into the motherbaord but it doesnt fit. and te 3 pin led switch comes directly from next to the power button
Can you show us these cables?
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
here you go the 3 pin rgb is already connected since it came from the top next to the power button and in the front there are rgbs too
this is the only fan
So i think there should be 4 pin fan headers called sys_fan or something similar but the 4pin fan plug looks a little different than usual, or the case comes with a proprietary fan hub, most likely in the rear if there is one
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
yes the 4 pin fan point is right under the 3 pin one but the problem is that there is no fan hub.
i have found that the sata cable has a extra extension that this one fits in to connect the front rgbs but then i dont know how to power them and the fan
There should be 4 pins on the motherboard though that the female 4 pin will attach to?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
yes i see the 4 pins but both of these dont attach to it
ah right okay, interesting, lemme do some research for ya then
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
The time stamped video talks about it here and includes some info and a few upgrades you can to do the case for airflow etc
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
oke ive watched the viedeo and i stll have virtually no idea what to do to power the fan  ive seen the pins but both of those dont work 😞
Id say it might be worth contacting oversteel's customer service just to ask wtf do i do with this fan cable
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
i think i know there is a 7 pin female strange cabl;e and i have no idea where to put that i have a msi 610 pro micro atx
