Questions regarding my first build (and component list):
11 minutes ago, BeemerBoi said:1. Am I under spending on the CPU?
UNDER spending? if anything your overspending for gaming and VR
11 minutes ago, BeemerBoi said:. Can this build support heavy VR gaming?
Should be fine
11 minutes ago, BeemerBoi said:Is there a better GPU I can buy for the price of the RX 6750?
not really, but in this budget for the whole build you can get a better GPU
11 minutes ago, BeemerBoi said:3. Cooler Master NR200P Max has built in PSU (Gold 80 and 850 watts more than enough) and a built in AIO (mounted to the top of the case as exhaust, negative pressure case.)
Only MAX I've seen (it's not on pcpp) is $400. Am i missing something?
11 minutes ago, BeemerBoi said:1. NVME would be primarily for gaming. The 3.5in internal hardrive would be used for school purpose
get one 4tb, it'd be the same price
TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (TM8FPW004T0C101) - PCPartPicker (around abouts)
11 minutes ago, BeemerBoi said:Is the Western digital drive fast enough for gaming purposes?
yes
11 minutes ago, BeemerBoi said:Is it worth trying to squeeze a couple of flim fans in the bottom of the case to act as intake? (The coolermaster case I chose is negative preassure)
What about on the side? I've got an nr200p and it has a choice of glass or mesh panel. use the mesh one and get two normal 120mm fans. Unless the 280mm rad up top doesn't allow for that, in which case mount the rad to the side and use two intakes up top, the two intakes at the bottom will be weak and focusing the GPU
11 minutes ago, BeemerBoi said:probably from Amazon or Newegg).
if only those two then try this (and you can oc the memory on the 7900 gre to get some (minimal) gains)
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($357.00 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler ($35.90 @ Amazon)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard ($144.00 @ MSI)
Memory: *ADATA XPG Lancer Blade 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($92.99 @ Newegg)
Storage: TEAMGROUP MP44 4 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($223.99 @ Newegg)
Video Card: ASRock Challenger OC Radeon RX 7900 GRE 16 GB Video Card ($539.99 @ Newegg)
Case: SAMA IM01 MicroATX Mini Tower Case ($55.90 @ Amazon)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($89.00 @ MSI)
Total: $1538.77
Generated by PCPartPicker 2024-03-27 15:16 EDT-0400
