Red VGA and no display
5 hours ago, AccDossNumber15 said:I'll try reseating, and yes they're fully in the GPU in on, it's hot, and the fans are spinning.
4 hours ago, AccDossNumber15 said:Ryzen 5 7500F unfortunately, no iGPU
Just to be sure that we are all on the same page. All cables, from displayport, pcie cable(meaning checking the psu if the cable is inserted correctly on the port that say pcie or checking if you are using the cables that come together with the PSU and the from an old or different brand/model), to reseating the gpu has already been check and done, right? and what you get is a no display, but fans and motherboards are on and lastly VGA LED is solid, correct?
Personally, this is why I don't like CPU without igpu. If it's was me, the first thing I will do after making sure all are slotted correctly, is to reseat CPU and check for bend pins on the motherboard as well. Basically, because I don't have a secondary GPU that I can try, I would first illuminate the CPU. There are times that the error is that the VGA isn't detected resulting on a solid VGA led light, but the cause is the CPU not correctly placed or some bent pins. Reseat ram as well.
Second is to try different displayport on both gpu and monitor(if available). I would even try to turn on the monitor first before the computer. If this is a new computer and first boot. I would also try to leave it on for a few at least 10-15mins. I would also try to use other pcie slot if available.
If that does not work, I would try to remove and clear the cmos. If that did not work, I will update the bios, so check if your motherboard support bios flash without cpu. As desperation sets in, I would disassemble the pc and just try to boot it using minimal components and just on the box of the motherboard. Lastly try to borrow a known working gpu.
