Max memory limit per slot in motherboard
Solved by WhitetailAni,
12 minutes ago, WhacKuum said:I have a Z370 Taichi which supports 64gb ram. Does that mean it only supports a 4x16gb kit or can it also support a 2x32gb kit? Is there a limit per slot?
From a bit of looking around, it seems that the system will POST with 2x32, but hardware reserve 32.
That, or just work - I am limited by what I can see due to stupid school filtering.
I'd get 4x16 if you can - if you already have 2x16, just drop another kit in.
