among them which motherboard's power stages are better??
Solved by goatedpenguin,
If your curious than a VRM is a Voltage Regulation Module, as the name implies it regulates the voltage that is being sent to the cpu and gpu(gpu has in built ones). Additionally, VRMs ensure that the cpu is receiving a steady and consistent voltage aka clean supply of energy. A power phase is like having power going through multiple channels hence, having a lighter load in each channel. This does get more complicated and goes down to some very technical electrical engineering stuff but you don't need to worry about this.
