AudioDG.EXE Faulty Aplication/Audio Device missing after first boot, sleep, and hibernation
HI there,
It's been month that my audio device went missing on the first boot and need a restart to make it appear.
But, when it goes to sleep and hibernation the audio is missing again and I need to restart it.
Downgrading and upgrading the driver didn't fix it, even using High Definition Audio.
Even after new fresh of windows install make no difference.
The audio is Conexant SmartAudio HD, using other device driver makes no different too.
Is it hardware issue or newer windows that messed up audiodg?
From the device events it said "requires further installation" but the driver program said it successfully installed.
Event Viewer:
Level    Date and Time    Source    Event ID    Task Category
Error    2/4/2024 3:12:07 PM    Application Error    1000    Application Crashing Events    "Faulting application name: AUDIODG.EXE, version: 10.0.22621.3085, time stamp: 0x718ed491
Faulting module name: CX64BP23.dll, version: 4.81.23.0, time stamp: 0x5639e209
Exception code: 0xc0000005
Fault offset: 0x00000000000660b6
Faulting process id: 0x0x10A4
Faulting application start time: 0x0x1DA5741D7F92D9A
Faulting application path: C:\Windows\system32\AUDIODG.EXE
Faulting module path: C:\Windows\system32\CX64BP23.dll
Report Id: 201d97ea-9a97-4b01-8722-d7b0c083fc25
Faulting package full name:
Faulting package-relative application ID: "
image.png.893b52037d34f5418dc480997692faee.pngimage.png.bc4fac0d4764f8ee1ffa46291201fd31.png
