My monitor has 165hz but it limits me to 144hz!
Solved by GuiltySpark_,
Just now, F.E.A.R. said:I was told that it's old tech and it's not compatible that's why the black screen cause.
That is blatantly false and I'd be suspect of any advice you receive from that person.
You'll need the higher bandwidth of DP 1.4 to achieve 165Hz at 1440p. Make sure the monitor is set to its DisplayPort input and if necessary try multiple DP ports on the GPU.
Featured Topics
Ivan M. ·
Posted in Storage Devices0 -
AlDowy ·
Xrniu ·
Posted in New Builds and Planning1 -
8
3
bleedpurple ·
Posted in Storage Devices2 -
geoffery ·
Posted in Troubleshooting1
