Is it ok if i leave the power on ?
Solved by Tetras,
47 minutes ago, LilyNightMoon said:can i leave the power point on even when the pc is off ?
Yes, but depending on the motherboard (e.g. USB power-on settings) and your other parts, it might draw a fair bit more power than when fully OFF. It is also more vulnerable to stuff happening on the same circuit (like power surges), but if you live somewhere with reasonable power, then it should be alright.
