Dual monitor stand dilemma
RageTester
My question is which one is better overall and for less neck movement.
One above the other should be easier to mount. Side by side you need to mount both at same time, if I understand it right. I have not bought extra monitor yet, and it would be nice to test with just 1, less risk if something fails and falls.
With number 1, you're just rotating your head or potentially just moving your eyes. Whereas with number 2, you'll be stretching your neck up and down as you move between displays.
I've tried the number 2 setup before and I honestly only found it useful for stuff I'll periodically look and monitor. Glancing over to my left/right was far easier and less tiring throughout the day than tilting my head back to fully see the upper display. So I never treated it as an active display when I was using such a setup.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
So I think I could mount the stand to monitors rather than monitors to stand. Lay them both flat on desk screen part down. Making sure desk is clean and nothing scratches the screens.
That would work right?
