How is it possible for air bubbles to form in an AIO pump which has been working without this issue for 3+ years?
6 minutes ago, em4n3m said:Right, so if one can't /isn't able to, should the AIO be replaced then a safety measure?
If it still works, you can of course still run it until it dies, since the CPU has overtemperature protections that will throttle it down or force your PC to shut down if the CPU overheats.
If you don't want to risk anything, you can replace it.
Featured Topics
BryanS24 ·
Posted in Troubleshooting1 -
Tall_Goat ·
Posted in New Builds and Planning6 -
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows1 -
BTGbullseye ·
Posted in Troubleshooting2 -
mark2999 ·
11
Sjokk ·
RockSolid1106 ·
Posted in Laptops and Pre-Built Systems1 -
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
