Sound of the UPS
Bazim
I wouldn't be so sure just google, others and ask other forums as well. If the sound is bothering you that much of course you can just get some foam and wood to stop some of the sound coming through
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Ye I found this on the internet:
Quote
When the UPS switches to battery power, it may produce a buzzing sound as it converts the DC battery power into AC power for your devices.
