Is this power cable meet the PS4 pro?
Solved by Needfuldoer,
11 minutes ago, IR76 said:Is this cable suitable for the PS4 pro?
C2G 88512 1 Metre UK Power Cable IECC13 to BS1363 3 Foot Kettle Lead Power Cord, Black https://amzn.eu/d/292WW9e
As long as the PS4 can take 240 volts and the wall plug matches your outlets, it will work.
The PS4 Pro has a C17 connector, which is just a C14 with no ground pin. C13 cables go with C14 connectors.
That entire connector range is a global standard.
