psu 550W PSU for temporary use
By
Taka07
in Power Supplies
in Power Supplies
Solved by TatamiMatt,
should be plenty 1060 is only 120W, 7800X3D is only around 90W leaving you near 300W headroom still
Thats a pretty monstrous build up until the GPU, are you planning to upgrade soon? If so you might run into some issues with power but should be fine when you get new one
reyrajesh ·
Posted in CPUs, Motherboards, and Memory9 -
1
5
1
TheHoffmeat ·
Posted in Operating Systems5 -
WarmEngine ·
Posted in Console Gaming3 -
1
