Not sure if my cpu cooler with fit with my ram and case
altimaltrim
Hi, everyone i'm not sure if the ram and the case will fit with my arctic liquid freezer ii 240 A-RGB AIO cooler. I am not bothered to find this out myself so can one of you guys do it for me please and thanks.
Link to ram: https://www.amazon.com/G-Skill-Trident-PC4-28800-CL18-22-22-42-F4-3600C18D-32GTZR/dp/B08176KLZT
Link to case: https://www.amazon.com/MSI-Premium-Mid-Tower-Gaming-Case/dp/B0899H96NQ?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&smid=ANEGB3WVEVKZB&th=1
Link to CPU COOLER: https://www.amazon.com/ARCTIC-Liquid-Freezer-RGB-Multi-Compatible/dp/B08WRJ5MQW?th=1
BTW, Im not Lazy. I forgot to mention that i dont even know if the radiator size will fit because it might be blocking my ram.
Lazy. and you said it yourself.
But I will say:  that's a kinda crap case, with poor airflow.
maybe you used the wrong words  'I am not bothered'  that says you do not want to waste your time looking into this and that others can use their time...
so yes the rad in some cases will create issue with the ram due to limited space..this is something you need to look into yourself, unless someone else has the same case and rad so knows, or someone else will look into this for you
Depends on the motherboard / where the dimm slots are located.
The ram seems to fit only when the fans don't overhang the slots: https://pcpartpicker.com/b/ykx6Mp
It won't fit if the motherboard has dimm slots that are too high up. https://pcpartpicker.com/b/PTrrxr
So the motherboard should have dimm slots no higher positioned than the slots on the MSI MPG B550 GAMING PLUS from the first example.
