RTX 3080 FTW VRAM Temps
Solved by Poinkachu,
23 minutes ago, Pikatchu said:Will layering the pads be bad? Or is it okay?
I have some left over pads from the waterblock, though might not have the correct thickness
Probs fine if it isn't too many
Correct thickness is VERY important.
Basically:
Too thin and the vram & stuffs might not get enough contact with the heatsink
Too thick and the pads might prevent the GPU die (and/or other section) from getting enough contact with the heatsink
You want it to be thick enough that it compresses a bit when you put on the heatsink, therefore ensuring good contact.
But not too thick that it prevents other section or your GPU die from getting proper contact.
