Help Dad with Loud GPU
2 minutes ago, mikeskix said:My oldest son said there a way to replace the fans with quiet ones. I'm clueless on pc and not even going to try.
It's called de-shrouding if you want to look up how to do it. It's not all that hard to do, it just takes a handful of zipties to get done right.
3 minutes ago, mikeskix said:I read about water cooling but did find any thing for graphics cards just CPU.
This would likely cost more than the GPUs are worth. Water blocks for GPUs are specific to that individual card, and usually cost in the neighborhood of $100+, not to mention the cost of everything else (fittings, pump, reservoir, radiator, tubing). Unless you're going to go very jank with it, using things like motorcycle radiators or other used water cooling gear, you would almost certainly be better off just buying new GPUs. Also, just saying, water cooling a GPU is harder than de-shrouding it, so this pathway is dead in the water IMO.
It's probably worth looking at the fan curve for these cards, as well as making sure the fan bearings themselves are OK. Unless you bought them brand new, it's not unlikely that they're ex-mining cards, and if that's the case the fans were likely run at 100% for over a year straight and the bearings are a little worse for wear and/or they flashed a mining BIOS to the cards that by default maxes the fan speeds out at all times. If you can lower the fan speed manually, that would quiet the cards down a bit and might make them tolerable enough to not bother with the aforementioned fan replacement techniques.
