I don't understand CPU power draw.
Solved by NavyCobra1417,
power draw: (number of transistors)*(frequency)*(capacitance)*(Vdd^2)
Voltage for the transistor is squared, this is important.
For transistors hit higher clock speeds, you typically need to increase the voltage.
Increasing cpu Voltage has an exponential effect on power draw as the voltage is squared.
Thus when overstocks are applied, often those last few hundred MHz require significantly more power.
