How much should I spend on RGB and aesthetics?
Hixyly
I plan to build a PC with a $1700 budget and love RGB lighting. However, I want to balance aesthetics with cost-effectiveness.
What's a reasonable amount to spend for RGB?
This is somewhat hard to breakdown like this. You don't generally breakout just RGB as a portion of the budget, as the RGB is generally a factor of the parts you put in the build, such as the memory, fans and GPU.
I'd suggest selecting the parts first and if versions of those parts include RGB and fit in your overall budget, there you go.
Enough to make you happy, but not so much that you sacrifice performance.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
Lol,
I have just gone through the same dilemma.
Tread carefully with RGB because the costs can get ugly.
I decided to upgrade a load of basic (but perfectly good Antec P12s) that cost about a fiver each to a full suite of Lian-Li Uni SL120s. 25 bloody quid each! And then you have pumps, blocks and reservoirs if your into water cooling.
Bedroom PC - Lian-Li O11 XL Evo - Intel Core i5 13600k @ 5.4P / 4.4EGhz -  MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - Gigabyte RTX 4090 - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Living Room PC - Hyte Y60 - Intel Core i9 9900k @ 5Ghz -  MSI Meg Ace Z390 Mobo - 16GB Ram - Palit RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i7 8086k @ 5.1Ghz -  Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA RTX 2080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office - Thermaltake Tower 100 - Intel Core i7 8700K @ 5.1Ghz - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - EVGA GTX 1080ti - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU + GPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 3770k - Asus P8Z77 I Delux Mobo - 16GB Ram - EVGA GTX 980ti - 256GB Corsair SSD - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 15TB Storage Server
Living Room AV Setup 5.1.4 - Yamaha RX-A2060 - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Yamaha RX-A1070 - 5 x Monitor Audio C265s (2 Zones)
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
Completely subjective.
Some people would say "$0, if it doesn't make the PC perform better than it's a waste of money."
It's your PC though and you have to look at it every day, so you shouldn't feel guilty about spending a bit to make something that looks nice to you and reflects your personality.
Certainly with a $1700 budget you should be able to make something which you find aesthetically pleasing and meets all of your functional needs. Just don't get suckered into buying parts that use RGB bling to camouflage poor functional quality (there are a lot of lower-cost cases like this, for example).
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
Unknowable
How much is comfy for you to spend.
25% is the common spend.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
i got like $5k in my system... 🤷‍♂️ of just rgb...
if i had to go it agane i would not go rgb...
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
I used to mock RGB.. until I bought ram with it, and a mobo with it, later a GPU with it, then a case with it, then some cheap fans with it..
When I want real performance I will swap them out to high performance models, but the one thing I like about RGB is that it is better than looking at just mobo lights 😄
AMD R7 5800X3D | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
