I am working on this pc: (went with amd due to low budget) but i dont know about a mobo, would a ROG formula V (Am3+, pciE 2.0) work? if there is a good one but cheap it would be better, for better graphics
AMD FX 8350
ASUS gtx 770 (if a cheaper MOBO is found i can go with a R9 280x)
1TB hybrid ssd
600/750 watt power supply, will check what i need
8 GB 2 stick of dd3 corsair vengeance low profile
Cooler Master k280
My PC:
MOBO: MSI B450 Tomahawk Max, CPU: AMD Ryzen 5 3600, Cooler: BeQuiet! Dark Rock 3, GPU: Gigabyte GTX 1050ti D5 4G, Ram: 16GB (2x8) HyperX Fury DDR4, Case: NZXT S340, Psu: Be Quiet! Pure Power 11 600W , HDD's: WD 1TB Caviar Blue, WD 256GB Scorpio Blue, WD 2TB Caviar Blue  SSD: Sandisk SSD PLUS 240Gb
https://linustechtips.com/topic/153255-am3-mobo-help/
Sabertooth 990fx r2 is basically the same as the crosshair v formula-z but a lot cheaper, if you want the best board then get those two. The gigabyte 990fx ud5 and ud7 arent bad either though
However, that power supply seems a little bit overkill, maybe 550?
But yeh that is a very solid build and i reckon it will run all games maxed out @ 60
@CookiezFort
Intel i7 4770k @4.5ghz, Asus Maximus VI Formula, Asus Geforce GTX 780, Corsair h100i, Corsair Neutron GTX 240gb, WD Black 1tb, Corsair 750D, Corsair AX860i w/ Sleeved Cables.
I rarely leave the build logs section.
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046258
Good, except one game xD, and that is Planetside 2, that shit is a beast that said company wont fix! so should i go with the R9 280X then?
My PC:
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046267
Umm.. the motherboard won't really change which GPU you can get, and the 280x is almost worse than a 770 and has some artifecting problems, but it can also be up to par, but regardles.. thats a waste of money.
price does
My PC:
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046272
Uhh for a FX8350 + ROG you can get i7 + entry level Z87 for same price pretty much...
I'd suggest i5 4670K + Z87 GD45 gaming
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046276
Up to you, the 280x has more vram which is great for higher resolutions but at 1080p gaming, the 770 comes in at better performance and price
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046282
ok i will go with 770 because of physx aswell
My PC:
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046313
AMD for me i believe is future proof, now not many games or anything uses the 8 cores in the future it will, getting the AMD will be future proof right?>
My PC:
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046354
Not when the i5 begins to exceed the multithreaded performance of an FX 8350.
Mobo: Z97 MSI Gaming 7 / CPU: i5-4690k@4.5GHz 1.23v / GPU: EVGA GTX 1070 / RAM: 8GB DDR3 1600MHz@CL9 1.5v / PSU: Corsair CX500M / Case: NZXT 410 / Monitor: 1080p IPS Acer R240HY bidx
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046439
No. A 5% multithreaded advantage is not going to make it more futureproof. Planetside 2 is a cpu bound game, basically every massive multiplayer games are cpu bound & lightthreaded. I'd rather get a 4670k+cheapest z87 board. Dont waste your money on a hybrid ssd/hdd theyre just shit. Get a simple 450W with the right amperage on the 12V rail to save some costs
Just go with the i5.
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046538
AMD FX 8350
1TB hybrid ssd
Cooler Master k280
i'm on a gigabyte board, it comes with a legacy pci slot adaptor
The big difference between the formula v-z is that the rog board uses an intel nic.
If I had known that earlier, i woulda gotten the formula v-z
the 990fxa-ud3 is as good as the formula v but costs wawy less
im using a Asus R9 280x dcuii OC, i do sometimes get problems with artefacts, but all you really have to do is restart the game and it'll be back to normal again.
I've probably have had 6 times at which artefacts have appeared.
Primary: 2017 Macbook Pro 15 2.9GHz with Aorus GTX 1070 eGPU / 512GB nvme ssd/ Samsung 840 pro 256gb/ Samsung 860 pro 512gb/ Samsung 27" CHG70 144Hz/ K95 / Razer Deathadder chroma
Secondary [AMD FX 8350 4.8Ghz/Gigabyte 990fxa-u3 v.4/ Asus R9 280x dcuii OC/Amd radeon 1866Mhz  32GB ram/ Samsung 840 pro 256GB x2/Naga Death Adder 2013/ corsair k95/ Dell 2312HM x 2/ Corsair 750D/ Corsair RM850/ Winows 7 Ultimate 64bit Backup : [AMD Phenom II 965 BE/MSI 790gx-65/XFX Radeon HD 4870/6GB Kingston Hyper X 1600MHz/Intel 520 480GB/OCZ Vertex 4 256GB/WD Black 500GB/Corsair Plat 860W/CM Advanced II Black & White/ /MX 518/Vengence k95/ Samsung 2333HD/vista64]Server- Intel i3 3220T / Asus H61M-A/16GB Kingston HyperX 1600/Intel 330 60GB/2TB x 3 WD Black/Sony Bravia 40" LED/Harman Kardon AVR 260 & HKTS 20 speakers/Ubuntu 13.04/ Fractal Node 605]
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2046734
go for a 990FX m/board if your using AM3+
many to choose from, the sabertooth gen 3 is a good buy no need for the ROG board as its for serious oc and advance users type board.
if you want even cheaper look at the other like the Gigabyte m/boards or and Asus M5A99FX pro R2.0 is ok if you like blue colour scheme.
If you can find a nice rev 2 / gen 3 sabertooth is really good board if you can afford it,
got to love Asus components
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2047741
This. Only reason to get an 8350 is if your budget is under $300 for both board and CPU. Also, only reason to get hybrid is for single-drive laptop usage. You're much better off with the cheapest SSD that you can get plus a regular mechanical drive for storage.
Oneplus 6 | Sony 55" X900F . Lenovo Y540 17" 144Hz RTX 2060 . i7 9750h.
Audio-GD DAC-19MK3 > Schiit Lyr 2 + > FOSTEX TH900 . Sony XBA-Z5
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2048194
Well, i am in pounds not Dollars, will see the price difference between the two builds
its about 100 pounds difference for me
My PC:
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2048737
I'm not sure how you managed to see that much of a difference.
CPU:  AMD FX-8350 4.0GHz 8-Core Processor  (£129.59 @ Aria PC)
Motherboard:  Asus Sabertooth 990FX R2.0 ATX AM3+ Motherboard  (£116.99 @ Amazon UK)
Total: £246.58
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-17 20:12 BST+0100)
CPU:  Intel Core i5-4670K 3.4GHz Quad-Core Processor  (£163.44 @ Ebuyer)
Motherboard:  MSI Z97 PC MATE ATX LGA1150 Motherboard  (£68.23 @ CCL Computers)
Total: £231.67
(Generated by PCPartPicker 2014-05-17 20:13 BST+0100)
A 4670k with a z97 board is even cheaper. If you want to make the amd build cheaper:
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  (£105.99 @ Amazon UK)
Motherboard:  Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  (£99.99 @ Amazon UK)
Total: £205.98
(Generated by PCPartPicker 2014-05-17 20:14 BST+0100)
Sorry but AMD is just too expensive for its gaming performance currently, games where you won't see a difference between the two a 80$ cpu would do as good as them. So it doesnt leave us that many options anymore to compare cpu's except massive multiplayer games which Intel always favors.
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2050422
faa..maybe he didnt compared the cheapest intel mobo vs the highest end amd? ...
amd is much cheaper everybodys knows that..
PCPartPicker part list / Price breakdown by merchant / Benchmarks
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard (£63.43 @ Amazon UK)
Total: £169.42
(Generated by PCPartPicker 2014-05-18 02:08 BST+0100)
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/153255-am3-mobo-help/#findComment-2051567
